×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Orbi RBR50 and RBS50 constantly disconnect or no internet access
inputchip
Tutor
This is a fresh install of the Orbi system, hit reset on both units before starting. System works great when it is working, however I am experienceing frequent drops in signal. Sometime it shows connected but no internet access, other times the router SSID disappears altogether, i.e. not broadcasting any signal.
Modem/Router from ISP: Hitron CGNM-2250 set into bridge mode
Orbi RBR50 (V2.3.5.30) router directly connected to modem via ethernet, 2 feet away
Orbi RBS50 (V2.3.5.30) sattelite about 25 feet away from Orbi Router.
This a is a used Orbi set that I picked up. It looks like V2.3.5.30 is the newest firmware version.
I contacted the ISP and everything seems normal on their end.
Anything I can try to get consistant signal and internet access? Really frustrating given the cost of these units.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 8
Accepted Solutions
CrimpOn
Guru
Re: Orbi RBR50 and RBS50 constantly disconnect or no internet access
Firmware 2.3.5.30 (from last summer) is stable.  There is newer firmware on the Netgear support site:
https://www.netgear.com/support/product/RBR50.aspx#download although my guess is that a firmware update is not likely to change things since you have already performed a "Factory Reset".
"Frequent Drops" appears to be one of the common posts, and I do not remember an obvious solution.
It certainly cannot hurt to perform a manual firmware update to 2.5.1.8 on both satellite and router, then "Factory Reset" both of them, and start over.
I love my Orbi.
Message 2 of 8
All Replies
CrimpOn
Guru
I love my Orbi.
Message 2 of 8
inputchip
Tutor
I'll give the update to 2.5.1.8 a try.
I just noticed that when the signal drops sometimes the satellite is solid magenta. Which apparently means:
"Solid magenta. Your Orbi satellite ring is solid magenta for 10 seconds if it is unable to obtain the IP address from the router."
Message 3 of 8
Guru
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 4 of 8
Retired_Member
Not applicable
The OP has stated he's going to try  2.5.1.8......so you might want to file this away.
Message 5 of 8
inputchip
Tutor
After completing the MANUAL update to the newest firmware, the devices seemed to be having even more difficulties staying connected.
It wasn't until I did a factory reset on both devices that things were staying connected properly, now running on 2.5.1.8. I've been using it for over 5 hours no with no drops in signal. Testing at 320mbps wirelessly on our 300mbps plan! Amazing speed.
Message 6 of 8
Guru
Be sure to do a backup configuration to file for safe keeping later on. Saves time if a reset is needed.
Enjoy.
Message 7 of 8
Retired_Member
Not applicable
Enjoy.
I guess we don't need Message 4 of 7
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 5811 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
