× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Orbi RBR50 asking for Password and Security Question that I never set up
tiki-monster
Recently, upgraded (re-signed) Spectrum wifi, and they actually said I don't really need to rent the Spectrum router, and just plug into my Orbi router.  Which I did, and it worked.  Until certain sites start to ask for IDs and Passwords. I've owned the Orbi RBR50 for a few years, don't recall setting anything up, and nothing I entered matched.
When I entered the serial number of the machine, it matched, and further went into more security questions that I didn't set up.
How do I bypass this problem?  Do I just hit reset?
I'm using Macs and iPhones in this household, and I have no access to a PC, just Macs.
Orbi RBR50 with 2 satellites.  One Mac is plugged directly into the router.
Thanks in advance.
Screen Shot 2021-06-23 at 9.58.44 AM.pngScreen Shot 2021-06-23 at 9.58.57 AM.pngScreen Shot 2021-06-23 at 10.02.33 AM.png
Message 1 of 9
Accepted Solutions
CrimpOn
Guru
Re: Orbi RBR50 asking for Password and Security Question that I never set up
A Factory Reset returns the Orbi to factory default settings:
  • The WiFi SSID/password are set to the values on the product label (bottom of the case)
  • The web browser administrative credentials are "admin" (which cannot be changed) and "password".
https://www.youtube.com/watch?v=cMw4ePACgc4
Open a web browser (Safari, Chrome) to http://orbilogin.netEnter "admin" and "password" to set up the router.
During setup, there will ba a page where you can choose the security questions to unlock the router if the admin password is entered incorrectly three times in a row.
Message 2 of 9
All Replies
CrimpOn
Guru
Message 2 of 9
Guru
Thanks in advance.
Message 3 of 9
tiki-monster
Currently, I'm only using the Spectrum internet's modem.  It is Model ET2251.  Outside of the box, it just said Spectrum.  Not sure who made it for them.  Charter Communications (Spectrum).
Message 4 of 9
CrimpOn
Guru
My recommendation is to unbend the paperclip, stick it into the Reset hole until the Power LED begins to flash amber, pull out the paperclip and then wait 2-3 minutes for the Orbi router to power up and connect.
In just under 3 minutes, the Ring light at the top of the modem should turn blue for a minute or so, and the Orbi should be "live".
Connect to the Orbi WiFi using the SSID/password printed on the product label (bottom of the case).  You should be "good to go".
Or, connect a computer to the Orbi with an ethernet cable.
If you are not happy using the default WiFi credentials, open a web browser and connect to http://orbilogin.net or http://192.168.1.1
The login credentials will be "admin" (which cannot be changed) and "password", which the router will prompt you to change.
Message 5 of 9
CrimpOn
Guru
Sorry. I did not get the notice that the problem is resolved until after I sent the last message.
"My Bad"
Message 6 of 9
tiki-monster
Just what I needed.
I guess I was just afraid of how long I was going to be out of internet, and didn't want to go to internet jail for any amount of time.
After watching that YouTube video, I grabbed my two satellites and proceed to reset my Orbi.
Downloaded the Orbi app on my iPhone, and followed the steps there.  Luckily, there were no more snags, and everything went smoothly to resetting.
Now, even if it comes back to ask me those pesky security questions, I now actually have an answer for them.  But no, none of the sites are prompting me to answer those questions.
Thank you.
Message 7 of 9
tiki-monster
No no no.  I followed YOUR ADVICE and got it solved.
THANK YOU!!!
Message 8 of 9
Guru
Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
Enjoy.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 4752 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
