Orbi WiFi 7 RBE973
Reply
Orbi RBR50 firmware and Disney Circle
Vicsternz
Follower
Says my router -Orbi RBR50 is compatible with Disney Circle and that firmware needs updating. However errors when app goes to update the firmware.
What is the correct version of the firmware that I need, where can I access it and does it work / are there issues with its performance?
Thanks very much
Message 1 of 12
bayoyong
Tutor
Re: Orbi RBR50 firmware and Disney Circle
I'm having the same issue. Can't add Circle. Brand new Orbi. RBR20.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 2 of 12
Starbucky
Apprentice
You need to load firmware V2.1.2.18 for the RBR50 and RBS50 for Circle and wired backhaul. It was pulled because there are some major issues for some users. A fix is supposedly coming.
Message 3 of 12
bayoyong
Tutor
Thx! How do I do that? And should I? Or wait?
Message 4 of 12
Starbucky
Apprentice
Well up until Saturday I would have recommended you upgrade/downgrade/sidegrade to the 2.1.x firmware but I started having wifi and reboot issues. So unless you are willing to put with some stability issues to get the Circle integration I would wait until NetGear releases a new firmware.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 5 of 12
bayoyong
Tutor
Ok thx again so much.
Message 6 of 12
ANBMKB
Initiate
Purchased RBR50 yesterday and spent several hours last night and tonight trying to get Circle running.  Finally found this message.  Thanks for providing and will wait for properly working firmware.
Message 7 of 12
bayoyong
Tutor
Hey Guys,
Ok, so I'm lame. My model is the RBR20. I was trying to update firmware for the RBR50. So close yet so far. Downloaded, installed the correct firmware for both R and S. Have Circle running fine. Thx again so much for your help!
Message 8 of 12
BigD56
I am glad you resolved your issue. I thought there might had been confusion over the model you were downloading as I mentioned in my last post with the files to use.
Message 9 of 12
Starbucky
Apprentice
I'm happy you figured it out. I also thought you might be using thr wrong model. I hope you find Cirle to your liking.
Message 10 of 12
Starbucky
Apprentice
Maybe my signature with model and fw version messed you up... Smiley Happy
Message 11 of 12
bayoyong
Tutor
Since you guys are so awesome, was wondering if I could ask another...I have Cox gigablast at home. Wondering how fast a connection I should expect with Orbi. Used to have a NightHawk. Speeds seem similar when nearby. Definitely better when upstairs thanks to Orbi. But only hitting about 300mb. Is that par for the course? On the NightHawk, I used to get 400-600...again when nearby.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 3008 views
  • 3 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
