Orbi WiFi 7 RBE973
Reply
Orbi (RBR50) looses connection frequently
jvanwijk77
Follower
H, I hope you are able to help me an issue I have. I recently bought the Orbi netgear (RBR50) with an additional satellite. The issue I have is that the connection seems to drop a few times a day now. Each time when this happens and I power on and power off the router the connection comes back again after a few minutes. I read that having one SSID for both frequencies might give a problem so I created 2 SSID's for either the 2.4 Ghz frequency and the 5GHz frequency. This did not help either.... the connection drops on a regular basis. The setup I have is the following: Telenet modem (Type: 24*8 DOC 3 WIRELESS(DOCSIS)) -- Orbi router i(via a cable) -- satellite (via a cable). The wireless signal of the telenet model is switched off. Could someone help me further with this issue? I just recently swiched off the wireless signal of the Telenet model to see if that gives some improvements. Gr, Johan
Message 1 of 5
Guru
Re: Orbi (RBR50) looses connection frequently
IF your ISP Modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Also try some of these suggestions:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Not seen on Orbi AX.
Message 2 of 5
velaramon
Guide
If you are w/i the return period, seriously consider that option.  The advice above about a double NAT is good.  However, the dropped-connections issue seems to span several years, several firmware versions, and many users.
Message 3 of 5
Guru
Lets see if this is a NAT issue first before jumping to conclusions.
Message 4 of 5
Guru
Let us know if you have any progress on this...
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1089 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
