- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 not talking to Network Solutions website
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Orbi RBR50 has stopped talking to my website provider, Network Solutions on Friday afternoon. I can't access my website builder tool nor can I check my email. Very frustrating. I can get to my website and check my email if I hardwire my computer straight to my cable motem so I know it's the router. I can also go to any other website no problem. Any insight would be helpful.
Thanks, Paul
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 not talking to Network Solutions website
Was it working before? if so, and you didn't change anything on the Orbi, I presume the issue would be a web site service issue, not a Orbi issue.
What is the Mfr and model# of the IP modem the Orbi is connected too?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Everything was working great Friday morning. Now, everything works as usual with every other site except this one
- Mark as New
- Bookmark
- Subscribe
- Permalink
If other sites and such work and this one site doesn't, it wouldn't be a router issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been reading other posts where people are having the same issue as me. I can hook my computer directly to my cable modem with a LAN line and it works perfectly. As soon as I hook my LAN line from modem to router and a line from router to computer, it's a no go for only that 1 site.
- Mark as New
- Bookmark
- Subscribe
- Permalink
modem is an Arris CM820
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a power off of the modem and Orbi router for 1 minute, then back on.
Might try a full reset on the Orbi router and setup from scratch....
- Mark as New
- Bookmark
- Subscribe
- Permalink
all done. nothing helped
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try different PC?
Contact this web site for help and information regarding this...again, if other sites work and this one doesn't, possibe site sevice isssue or DNS issue.
Try using 1.1.1.1 and 9.9.9.9 DNS on the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
actually might not have done a full reset on the Orbi. How is that done?
- Mark as New
- Bookmark
- Subscribe
- Permalink
and even my iphone can't get emails from my website when I am on the Orbi wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hold the reset button on the router til the top LED turns on Amber or use the Web UI under Admin/Backup to do a reset. Either one will work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. I'll try that
- Mark as New
- Bookmark
- Subscribe
- Permalink
See if you can ping it and tracert to it. The issue could be with your DNS, or it could be a security setting, like blocked sites. If you haven't already done a factory reset, you can look into those.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If your ISP does run a DNS cache, also negative results will remain cached for a certain time - these DNS caches won't do new queries for a while. As the routers pick up the ISP supplied DNS servers commonly, they just reflect what's there - or not.
Seriously, I don't think a consumer router DNS queries (implemented by dnsmasq) does fail or block a single domain only.
Not very difficult to check, just figure out the DNS servers configured. query these for the domain the www, the mail, smtp, pop, whatever in question. Then compare e.g. to the big public DNS, example is using google.com:
C:\> nslookup
> server 8.8.8.8
Default Server: google-public-dns-a.google.com
Address: 8.8.8.8
> google.com
Address: 8.8.8.8
Non-authoritative answer:
Addresses: 2a00:1450:400a:801::200e
172.217.18.14
> server 1.1.1.1
Default Server: one.one.one.one
Address: 1.1.1.1
> google.com
Address: 1.1.1.1
Addresses: 2a00:1450:400a:802::200e
172.217.168.46
Instead of the 1.1.1.1 or the 8.8.8.8 enter a) the router LAN IP, and b) the ISP supplied DNS and query your domain.
