- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 reset fails / not possible
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi! I have the RBR 50 Kit with two satellites. Till last week all was fine with the mesh network but suddenly, the RBR50 stopped to work. I tried to do a reset (in all kind of ways/power off, pressing reset button etc) which is not possible - the power light is green but doesn't change to red blinking status. Also no SSID is showing. Is there a way to connect directly via lan-cable from the PC?
Maybe the hardware is faulty...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 reset fails / not possible
@Shintom wrote:Hi! I have the RBR 50 Kit with two satellites. Till last week all was fine with the mesh network but suddenly, the RBR50 stopped to work. I tried to do a reset (in all kind of ways/power off, pressing reset button etc) which is not possible - the power light is green but doesn't change to red blinking status. Also no SSID is showing. Is there a way to connect directly via lan-cable from the PC?
What firmware are you running and how did you get it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
As I can't access the router I don't know the firmware - is it possible to access via lan cable direct from my pc? If yes how to do?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Shintom wrote:As I can't access the router I don't know the firmware - is it possible to access via lan cable direct from my pc? If yes how to do?
Certainly. Connect ethernet cable to one of the Orbi LAN ports. Open web browser. If Orbi is working correctly, you can browse to http://orbilogin.net. If something is out of the ordinary, the trick is to find the IP address of your "gateway" and connect to http://<ip of gateway>
Log in with credentials "admin" and the administrative password (not the WiFi password).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Perfect, I could log in, Router Firmware V2.3.5.30
- Mark as New
- Bookmark
- Subscribe
- Permalink
After I connected via lan-cable now also the LED starts to work again...
- Mark as New
- Bookmark
- Subscribe
- Permalink
