Orbi WiFi 7 RBE973
Reply
Orbi RBS50 Satellite Blue, but not connected completely?
mpdono
I have a 6 satellite system that has worked great for some time, but all of a sudden my Orbi RBS50 Satellite in my basement has started acting up.  I can't wrap my head around what the problem is given the criteria below.  Any suggestions would be greatly appreciated.
- RBS50 Satellite seems to sync fine, top ring turns blue on the device itself
- In the application, the satellite just shows "not connected"
- Devices hardwired into the satellite do indeed get an internet connection, but a spotty one
- When trying to update the firmware, it claims that the latest version is on there (which is the same as my router and other satellites) V2.7.2.104; however it is the only satellite in the list that gets stuck on "Waiting for connection"
I can't figure out why it would turn blue and why devices would have a connection at all if the satellite is unreachable/not connected.  Any suggestions out there?
Message 1 of 8
Guru
Re: Orbi RBS50 Satellite Blue, but not connected completely?
Try moving the RBS near the RBR to update it, or download the RBS FW file to a laptop and wire connect to the back of the RBS and use the RBS web page to update the RBS directly.
Swap locations with a different RBS.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Message 2 of 8
mpdono
Thanks for the reply.  The home is about 5k sqft, but one of my 6 satellites is an outdoor satellite as well.  I have about 30 ft in between these two satellites.
The dashboard had stated that the most up to date firmware is already on there.  What am I looking to update to?
Message 3 of 8
Guru
5k sqt feet and you have 6 RBS? I have some size home and only use two RBS.
Try swapping locations with this RBS with another RBS. See if problem follows...
So all RBS have same version of FW as RBR?
Message 4 of 8
mpdono
Yes, unforunately I needed extra satellites, I think due to the length of the house.
This particular satellite hasn't had an issue for 2 years until now.
Yes, all RBS satellites have the same FW as the RBR.
Message 5 of 8
Guru
Message 6 of 8
mpdono
Thanks for chiming in, I figured it out.  After testing a different satellite in that location, I had the same problem.
I then was able to narrow it down to the problem only occuring when some of my other devices were plugged into the back of the satellite.
I recently had to get a Sonos Boost for different reasons and it appears to me that it changed the ZonePlayer, which was plugged into the satellite having issues, was trying to connect wirelessly and through the wired connection at the same time.
For whatever reason, while this was happening, the satellite would drop in and out repeatedly.
Unplug the Sonos ZP1 and the satellite works like a champ.
Message 7 of 8
Guru
Sonos has there own wifi radios I believe. Something you might look into with Sonos and see what can be done there.
Glad you figured it out.
Please mark your thread as solved so others will know.
Enjoy. 📡
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2736 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
