computerpitstop
Sep 14, 2024Follower
Orbi RBS50
Will not reset
1 Reply
A bit more detail would be helpful.
The "reset button" in these instructions refer to a button on the printed circuit board inside the case that can be reached through that tiny hole in the case labelled "Reset".
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Sometimes it is difficult to hear (or feel) an indication that the button was actually pressed. It often takes 10-15 seconds for the power LED to begin to flash.
When this recommended method fails, there are reports of people performing what is called a "30-30-30" reset. i.e.
- Hold the reset button for 30 seconds.
- While still holding the reset button, remove power from the device and wait 30 more seconds.
- While still holding the reset button, apply power to the device.
90 seconds is a long time to hold that invisible button. At least the RBW50 has a physical Power Switch. Newer Orbi units have no Power Switch and the only way to remove/return power is to (a) unplug/replug the power cable, (b) unplug/replug the power supply from the electrical supply, or (c) connect the power supply to a physical switch.
