× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Orbi RSR50 Satellite connectivity
Dtdriscoll
Follower
I have a RSR50 router and two satellites.  All of my devices are connected to one satellite and the 2nd satellite has no devices connected.  How do I balance the satellites?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Orbi RSR50 Satellite connectivity
Do you have the SRR50 or the RBR50 system?
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Devices pick and choose which signal source to connect too based on distance, signal, and noise. ALso if one RBS was turned on after the other RBS, then most of the devices will have already connected to the other RBS that was on already and won't connect to the 2nd RBS until they are moved or disconnected from the RBS.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 448 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
