Orbi WiFi 7 RBE973
Reply
Orbi SSID not appearing
s22tran
I have an Orbi RBK50. When I turn on my router and satelite, the SSID does not appear on my network list. The pin hole reset button is initially unresponsive as well and after a while (more than 5 minutes later) I am able to use it to reset with no change in the SSID apperaring.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Orbi SSID not appearing
Hello s22tran
Are you able to log into the orbi using the ethernet cable and change the SSID?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 800 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
