Orbi WiFi 7 RBE973
Reply
Orbi Satellite RBS50
oabdali
I have had RBS50 for sometime now like 2-3 years. I have 3 satellites usually connected wirelessly without a single issue. Now I have created a new underground room and connected it using ethernet to one of the satellites (i moved it there). the satellite keeps disconnecting every minute or so. I notice it more when I connect my iphone to it. All devices on firmware v2.7.3.22 any ideas?.
Message 1 of 6
Accepted Solutions
oabdali
Re: Orbi Satellite RBS50
Connected to RBS and yes Cat6. The satellite has been synced when it was in the other room. It is a bit far to try to connect them wirelessly but i can try…
Message 3 of 6
All Replies
Guru
Is the RBS connected to the back of the RBR or another RBS?
What CAT# lan cable is being used? CAT6 is recommended.
Did you first sync the RBS to the RBR wirelessly, then after thats synced, plug in the RBS via ethernet cable?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 6
oabdali
Message 3 of 6
Guru
As a quick test, does the one RBS connect to the RBR and sync ok?
Wondering if wiring to another RBS maybe a problem.
Message 4 of 6
oabdali
Somehow it worked but it is connected wirelessly for some reason. I will keep you updated
Message 5 of 6
oabdali
Unfortunately, the problem still persists. I think i will have a technician to come look at the wiring.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 668 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
