Orbi WiFi 7 RBE973
Reply
Orbi-Secondary Network/NAT
r24481
Follower
I have a secondary network via a router(10.2.1.0/24) that forwards to an 192.168.1.x which then forwards to the ORBI default gateway of 192.168.1.1 I have no issues pinging 192.168.1.1 however I cannot get to the internet. Should the orbi NAT any address by default or is there a way to tell it to NAT the 10.x network or is this simply not possible and I have to nat at ingress to a my 192.168.1.x gateway?
Thanks
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Orbi-Secondary Network/NAT
Can you send me a PM with your contact info support would like to work with you on this issue.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 586 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
