Orbi WiFi 7 RBE973
Reply
Orbi Setup
Fbombtom
Orbi Setup
I have a Spectrum modem and it is connected to a Netgear Nighthawk router.  I would like to expand my wifi coverage in my home and was looking at the orbi.  I was wondering how the orbi would be hooked up to my set up and would it use the Nighthawk wifi?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 3
aaz
Virtuoso
Virtuoso
Re: Orbi Setup
No, the Orbi does not use the WiFi of another router as it is not a extender.
If you are using particular features of the nighthawk as a router that the Orbi doesn't have then you could just turn off the Wifi in the Nighthawk and use the Orbi as an Access Point. But, really I would recommend go with the simple setup and just sell the Nighthawk and replace the router with the Orbi.
Message 2 of 3
Fbombtom
Re: Orbi Setup
Thank you for the info.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 563 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
