- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Voice model RBS40V, Alexa not responding to voice command or playing through the speaker
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Orbi Voice shows connected to my Alexa device (Echo Dot), but will not respond to voice commands. It worked initially but once I unplugged my router to relocate it, the issue started. It will receive my Amazon notifications and display a yellow pulsing light, and when I press the button on top, I get the blue and cyan colors like it's listening, but no response.
I've tried unplugging everything and unsyncing/resyncing, but still not working...any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Voice model RBS40V, Alexa not responding to voice command or playing through the speaker
Well, after registering the product on MyNETGEAR, clicking the support tab and creating a case number, calling the phone number in the email provided, 35 minutes of hold time after being number 21 in the queue, and then speaking to a rep who says I contacted the wrong department, she tells me she would have to transfer me to "the appropriate department." I specifically asked if I would be placed back in a phone queue and said "no, I'm just transferring you back to the approriate department," but low and behold I am 13th in a call queue again. Total call time right is 47 minutes...not too impressed with product support at this point but hopefully it gets resolved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok, one hour and 12 minutes since I initially called and now I've connected to a second rep who just wants to clarify that I have a "router with a bulit-in Alexa." ....
"Well, no, I have a Orbi Voice satellite and the voice function is not working with my Alexa."
"Yeah, that's what I mean you have a satellite with a built-in Alexa."
"oh, ok, yes."
"what error message is it giving you?"
"I'm not getting an error message. It just doesn't respond whe I say "Alexa" and nothing comes from the speaker"
"ok, let me place you on hold"
- Mark as New
- Bookmark
- Subscribe
- Permalink
After one hour and 55 minutes on the phone, I was placed on hold and the call dropped. The rep called me back and says I need to contact Amazon. Per Orbi rep, everything is fine on their end and my router is functioning properly, so I need to be tranferred to Amazon. Orbi rep was able to connect me to Amazon phone support. The automated message on Amazon states they cannot reached by phone at this time because of the COVID issues and it disconnected.
Unbelievable. Thanks for the help Netgear/Orbi. /sarcasm.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I contacted Amazon through chat and they referred me back to Netgear/Orbi. At this point I have completely set up everything as though it were new and nothing. At this point, I do NOT recommend the Orbi Voice. Save your money on the gimmick factor and just but a regular satellite and a $30 echo dot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
UPDATE: still doesn't work, but I got an email from NETGEAR asking if I want to sign up for extended tech support for a mere $50. Maybe if you could have resolved the issue on my brand new product, I'd consider it. As of now, it's just insulting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
during initial setup did you get prompted to set up alexa on the satallite? also, what does it show for firmware version, and did you try doing a factory reset of the satallite? you might also try doing a factory reset of the router and start from scratch. you did say it worked when you first setup the system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
During initial setup I did get prompted to set up Alexa. I followed the propmts and it was very easy. For a short time it worked as it should, then when I unplugged the router to relocate it, the Orbi Voice started doing what it does know. Still shows connected, shows up on my Alexa app, and will get the yellow notification ring so it's obviously linked to my Amazon account, but it doesn't play any sound won't respond to "Alexa,..." It's almost as if the speaker and microphone are disabled, but the red x's next to each of those buttons are not illuminated.
The firmware version is V2.5.1.2, and yes, factory reset was done several times now.
I reset the router and did the complete setup as if it were new three times now, and still the same issue. The Orbi Voice works fine as a regular satellite, just annoying that it doeesn't function as it should.
- Mark as New
- Bookmark
- Subscribe
- Permalink
very strange. when you ask alexa something and you get no response, does the blue ring on top of the 40v still come on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
also, check the alexa app and make sure you don't have "do not disturb" for the 40v engaged.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did confirm the do not disturb option is not activated.
The blue ring on top of the 40v does NOT come on when you say "Alexa," as it did previously. If you manually press the button on top on the unit, the blue ring will illuiminate.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok, next in the orbi app open the 40v satallite and confirm it is logged in to alexa.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, logged in per the Orbi app
- Mark as New
- Bookmark
- Subscribe
- Permalink
well thats all the simple things that would cause your issues. it's obvious the mic is not working. whether it is a hardware or firmware issue is not clear. try this, connect your 40v to the router via ethernet (reboot the system) to see if anything changes. if not while you have it connected via ethenet try to reinstall the firmware. if all that does not work and you cant get satisfaction from netgear support, i would return it for a replacement.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will give it a try and update the post. Thank you for the suggenstions and help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was really hoping somebody from Netgear would have at least tried to chime in, but no.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just got mine and finished setting up and I'm finding the same thing. The blue light is on indicating that Alexa is listening, but she won't do anything.
I got it to play music... not through Apple Music mind you. The fact that it doesn't work with Apple Music is a HUGE problem now. But since Alexa doesn't seem to hear anything it now won't shut off. I had to pull the power to get it to shut up.
I also noticed the red X next to the microphone randomly turned itself on.
Within 10 minutes I'm learning that this thing is a disappointing piece of junk. Netgear, what say you?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
When you factory reset the RBS40V, did you change the mode back to Orbi? When I got mine last week I had to change it to Orbi, then set it up.
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Mstrbig wrote:When you factory reset the RBS40V, did you change the mode back to Orbi? When I got mine last week I had to change it to Orbi, then set it up.
Changing to Orbi mode apparently only works if connecting to an Orbi router, which I am not. I only found this out after going through the tedious process of resetting the Orbi Voice. Now it is even more useless than before. I have to reset the whole thing again and try to reconnect it in the way it was only working half-way well to begin with. This advice was terrible. Thanks for nothing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Didn't you investigate before purchasing? Without an Orbi router you have to run in extender mode. But it should have nothing to do with the OP's question regarding controls. Changing it back to Extender mode is an elementary procedure if you follow the directions.
Could it possibly be you didn't leave enough information, when you were asking for help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah… the key statement "it should have nothing to do with the OP's question regarding controls." Yet it does. The product claims to work with non-Netgear/Orbi routers as an extender/Alexa speaker. It works like 70% of the time. The controls are REALLY glitchy. Volume control is haphazard or non-existant. Could it possibly be you offered a solution without being familiar with the problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@BrollAmerican wrote:Ah… the key statement "it should have nothing to do with the OP's question regarding controls." Yet it does. The product claims to work with non-Netgear/Orbi routers as an extender/Alexa speaker. It works like 70% of the time. The controls are REALLY glitchy. Volume control is haphazard or non-existant. Could it possibly be you offered a solution without being familiar with the problem?
The product absulutely does work with Non Netgear/Orbi routers as a WIFI extender and Alexa compatible speaker!
Yours working 70% of the time could mean defective for sure. Did yoy buy it brand new or used? If new you can return it or exchange it, as it may be faulty. If used, it may have had that problem when you bought it.
I'm very familiar with the product, as I install many of them and never had a bad one, and own one myself.
