× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Orbi and other Routers
MightyT
Star
Does the Orbi Satellite work with other Netgear AC Routers?
Message 1 of 8
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: Orbi and other Routers
No.
You would need the Orbi router to have a wired connection to the R6300 using Ethernet if you want to use both R6300 and the Orbi and put one of the Orbi router or R6300 in access point mode.
The Orbi Satellite connects to the Orbi router only.
Message 6 of 8
All Replies
DarrenM
Sr. NETGEAR Moderator
Hello MightyT
Can you be more specific with the question? Are you asking if you can connect the orbi to existing routers?
DarrenM
Message 2 of 8
MightyT
Star
Yes, my NETGEAR R6300 Router
Message 3 of 8
DarrenM
Hello MightyT
Yes you can either use orbi as your main router and connect the R6300 to it and make it a access point or you can connect the orbi to the R6300 and make it a access point.
DarrenM
Message 4 of 8
MightyT
Star
OK, so it sounds like I can continue to use my NETGEAR R6300 Router downstairs and set up an Orbi Satelite upstairs and get the greater coverage upstairs I am looking for as if I have to Orbi's.
Thanks!
Tony
Message 5 of 8
mdgm-ntgr
No.
Message 6 of 8
sapaulsen
so does that mean that if I put the Orbi router in AP mode, it takes on the IP addressing scheme of my router which is handingout 192.168.0.x IP addresses. I want to make sure that the Orbi is on the same IP address network as all my devices on my network. Please confirm is that is correct.
thanks!
Message 7 of 8
DarrenM
Hello sapaulsen
Yes if in AP mode the main router it is connected to would handle the DHCP and assign the IP address.
DarrenM
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 4694 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
