riteoh123's avatar
riteoh123
Orbi blocking ftp??
I hope somebody can help me with this problem (and that I am explaining it properly)
Earlier today I changed my web hosting package from a dedicated IP address, to a shared service.  Since the change, I have not been able to connect to my site using ftp and wifi - however I can connect when not using my home wifi.
I can also connect when using a site such as net2ftp.com.
This is telling me that something on my home wifi (Orbi??) is blocking the connection to this site.
Does anybody have any idea firstly about what I am talking about, and secondly, an easy way to fix it?
Any replies must be fairly simple to follow - I am not after technical instructions, as they will be far too advanced for me to follow!
Thanks in advance.
  • CrimpOn's avatar
    CrimpOn
    Orbi does not block any protocols, certainly not ftp.  Are you accessing the new hosting service by IP address or by URL?
    • CrimpOn's avatar
      CrimpOn
      Forgot to ask which ftp client software is being used.
      • riteoh123's avatar
        riteoh123
        I am trying to access using the IP address. I have used both FileZilla and CoreFTP.  If I try to access using my PC and wifi - cannot access. If I try with my phone and wifi on - no access. As soon as I turn wifi off, and use mobile data - success!! However this is not a solution to the problem - only a means of troubleshooting.
        Can the IP address be blocked or something like that?
