- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi connection status is offline
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just switched modems and when I connect the Orbi up it says my internet is offline.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, this is a gateway modem/router.
A few configurations when using this kind of modem:
1. Fully bridge the ISP Modem.
2. If the modem can't be bridged fully, input the IP address that the Orbi router gets from the ISP modem, in to the modems DMZ keeping the Orbi router in router mode.
3. Keep the modem in router mode and configure the Orbi router in AP mode.
@tomcat81 wrote:
It is an ARRIS BGW210
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi connection status is offline
Does the new modem work if you bypass the Orbi and just connect to it directly?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
whats the Mfr and model# of the ISP modem? Built in router here by chance?
@tomcat81 wrote:Just switched modems and when I connect the Orbi up it says my internet is offline.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
While I appreciate your response to help me, but I have no idea how to do all that. But, its fixed now. I had to reset it to all factory settings and sync it like a brand new router. Works just fine now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, I would contact your ISP and have them help you with your modem. Either bridged or use it's DMZ for the Orbi router.
Enjoy.
