×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Orbi devices (Router/Satellite) have a slight "wobble) to them.
Namdnas
Tutor
Hello!
Loving my Orbi!  However, I can't help but notice one thing and I'm not sure if it's intential or not, maybe due to the build/shape of the device?  Both my router and satellite have a slight front to back, back and forth "wobble" to them.  Almost like the side pads on the bottom are just a hair mm thicker than the front/back ones.  It's like this on both devices.  I was just curious if this is the normal nature of the design or if it's an actual design flaw?  Does anyone else's do this?
Thanks!
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Orbi devices (Router/Satellite) have a slight "wobble) to them.
Hello Namdnas
I Tested mine and it does have a slight wobble as well.
DarrenM
Message 2 of 3
Namdnas
Tutor
Awesome, thanks.  My train of thought was if only one of them did it, it might be a flaw, but if BOTH of them did it, then, you know.  LOL.
Message 3 of 3
Discussion stats
  • 2 replies
  • 2445 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
