jumuj's avatar
jumuj
Follower
Nov 09, 2023
Orbi jitter issue
I've got an Orbi RBK23 with 2 satellites, the router is connected to a switch which connects all the wired LAN in the house, there is wired LAN outlets in most of the rooms but the one I use as the office does not so I've been relying on the mesh wifi.
The issue I'm having is there is terrible jitter and latency which is causing MS team calls to cut off audio randomly. I've fixed this by running a LAN cable from another room to the office, is there any options to use one of the satellites as an access point? Or any advice as to what I can do to minimize latency so I can ditch the cable?
1 Reply
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, Smart Parental Controls or Circle, Traffic Meter.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
