Orbi WiFi 7 RBE973
Reply
Orbi mesh spectrum problem
Smilingsallyjun
Spectrum had to update and reboot my system. My orbi will not reconnect.  I have gone through all the steps numerous times. It does not even recognize that it is plugged into modem.  I have never had trouble before.
Message 1 of 9
Guru
Re: Orbi mesh spectrum problem
Power OFF both ISP modem and RBR for 30 seconds, then back ON with the ISP modem first, then the RBR.
Message 2 of 9
Retired_Member
Not applicable
what type of spectrum gear are you running?
have you tried to simply reboot your entire network?
Message 3 of 9
Smilingsallyjun
My spectrum equipment is model # TC8717T. I did rebot and also tried all the suggestions on Orbi app. Nothing has worked so far.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 4 of 9
Guru
Your modem already has a built in router and wifi. What mode is it working in? Router? This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 5 of 9
Retired_Member
Not applicable
I have to ask.....how long have you had your Orbi?  Has it ever worked with the Spectrum gear?
Or.....did you buy the Orbi not relazing that as a package, it has its own router?.....and that you would end up with 2 routers?  Huh?
Just some questions?
Message 6 of 9
Smilingsallyjun
My orbi has worked great with my spectrum until they rebooted it. I know i now have 2 routers. It wasnt a problem until now.
Message 7 of 9
jimthomas858
Had the same problem. Did everything i could think of to clear not obtaining a DHCP served ip address from the WAN. I even rest back to factory defaults.
Worked with spectrum. They flushed the mac from their cache and everything else.
Direct connect from my computer worked.
Switch back to my old crappy router and it worked......
Returned my Orbi . Really bummed cause it worked great for 12 hours.
Message 8 of 9
Guru
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 3971 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
