Vand's avatar
Vand
Follower
Mar 09, 2023
Orbi netgear router rbk13
Hey there, is there any way that I can reset the password on my router? I didn't set it up and the person who did doesn't remember. I'm trying to setup my router for wifi, it keeps wanting me to login to orbi router with username "admin" and password. If I try to go back, it exits the app.
1 Reply
  • plemans's avatar
    You'd need to factory reset as more than likely they didn't setup the password recovery option either (or don't remember the answers).
    To factory reset, push and hold reset for 7-15 seconds while powered on.
    that'll get you back to the defaults and then you just need to reinstall it.
