× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Orbi rbk 50
NYGFAN106
Follower
Orbi rbk 50
I have been having bad performance out of my product since getting it today. I can run a speed test by login on 192.168.1.1 it usually shows it at 494m downloads and 286 m uploads. Then when I run the speed test on the speed test app it shows it around 1.00 m or lower, even timing out.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Guru
Re: Orbi rbk 50
Are you speed testing with a wired or wireless device? Wired speed test is preferred to start.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 339 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
