- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi rbk12 question for a small location but fast internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi everyone,
I am new to the forum and am looking for advice with maybe buying an Orbi RBK12 for a small place about 1000ft. I have a 200Mbps cable internet connection and was wondering if that would be capped to 100Mbps or lower and I wouldnt be able to get the full bandwidth. Can anyone confirm this? I can't find anything that says how much the WAN port could support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi rbk12 question for a small location but fast internet
How would your speed be capped at 100Mb? Unless your wired PCs network adapter was only supportive up to 100Mbps. Then you would see the cap there.
The 1 series Orbi has the following specs: https://www.netgear.com/images/datasheet/orbi/RBK12.pdf
Ports – Orbi Router
- Two (2) 10/100/1000Mbps Gigabit Ethernet
ports
- One (1) WAN & one (1) LAN
Orbi AC1200 Router & Satellite
(866 + 400Mbps)†
What Firmware is currently loaded? Built in router here by chance, if so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options to consider,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find all the documentation for your hardware.
The specifications are in the manual.
Netgear has not made "fast Ethernmet" for some years. It is all Gigabit Ethernet these days.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Make sure that the network patch cable you use between your modem and the WAN input of the router is CAT5e, CAT6 or CAT7 to be able to handle gigabit speed. A CAT5 patch cable is only good for 100Mb/s speed. If your cable it CAT5e or greater, then try another patch cable in case the one you have is defective (kinked or broken wires within it causing shielding/noise issues that degrade its speed).
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
