Orbi WiFi 7 RBE973
Reply
Orbi router does not recognize satellites connected to the switch
dirceuguerra
good morning everyone! I have encountered an annoying problem that has been taking time and I honestly don't know what to do. I've been trying to install a switch (dlink DGS 1008A) for two days on my Orbi system, but whenever I connect a satellite to the switch, it seems that the satellite stops responding. The app shows that it is connected via 5G and shows no wireless connection. My system is configured in an Orbi router (RBR 50) and three satellites (one RBS 50 and two RBS 40) connected at the router. All satellites have a reserved IP. daisy chain option off. Can someone help me? I need to add more ports to the router.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router, RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 10
Accepted Solutions
dirceuguerra
Re: Orbi router does not recognize satellites connected to the switch
Then the new switch arrived (a TP-Link model) and ... it worked! Apparently the problem was the switch! Thank you all guys!
Message 9 of 10
All Replies
Guru
how it it connected?
it should go:
gateway----->wan port on orbi router------>lan port on router to switch------>satellites.
Message 2 of 10
dirceuguerra
Hi!
It is connected like this:
ISP Modem -----> Orbi internet port (Orbi is in router mode) -----> LAN port on Orbi router to LAN port on switch -----> Orbi Satellite connected at switch's LAN
Model: A6100|WiFi USB Mini Adapter
Message 3 of 10
Guru
what firmware is on the router and on the satellites?
Have you tried a different switch?
Message 4 of 10
dirceuguerra
They all are using the latest firmware (V2.5.1.16)
I bought a new switch and it should probably arrive today. But a behavior that I found strange is that if I connect the switch to a free port on some satellite, everything works normally. The problem is when I connect a satellite directly to the switch.
Message 5 of 10
Guru
I've heard of some of the "green" switches having issues. I've never had an issue and have 2 of them on my network.
Message 6 of 10
dirceuguerra
Yes, I was just reading about green switches. I've never heard of it! And worse: the new switch I bought has this green configuration.
But at the same time, as I said, It's a very strange behavior because I only have problems when I connect satellites. All other devices work fine.
Message 7 of 10
Guru
What is the Mfr and model# of the ethernet switch in the configuration?
Message 8 of 10
dirceuguerra
Message 9 of 10
Guru
Glad to hear you got it working!
If you mark it as solved it can help the next person with that issue
Message 10 of 10
Discussion stats
  • 9 replies
  • 1928 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
