- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi routers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi routers
Is it possible to use my old Orbi Router and satellite with the newest Orbi system in order to expand the range of my current setup?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi routers
What actual systems do you have? It matters model wise.
Will a new AX system integrate with the old AC system? No. but you could connect the old system in access point mode (with different ssid/wireless channels) and use it in conjunction with the new system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi routers
I have an RBR20 main router and RBS20 satellite.
So they won't work to extend the range? only as access points?
Would that mean that if I was on the other SSID any networked devices on the new ssid wouldn't work? (or opposite if I changed the ssid on the newer routers to what is existing)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi routers
Hello minkus,
Welcome to NETGEAR Community!
I understand that you are looking for information about compatible devices with your RBR20.
The RBR20 is compatible with the following Orbi AC Satellites - RBS10, RBS20, RBW30, RBS40, RBS40V, RBS50, and RBS50Y.
Best,
Kevin
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
