- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi satellite losing connection with router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have had my Orbi mesh system for close to a year. For the past month or so, I have been experiencing random satellite drop connections. There is no indication from the affected satellite of its aliment. The only way I can tell is by devices connected to the satellite losing wifi, both hardwired and wirelessly. When this happens and I open up Orbi APP or orbilogin.net, then I can see the satellite is having connection issues. If left on its own, it would reestablish connection within 5 mins or so. But this is extremely annoying and random. And it happens multiple times a day that it drove me nuts. How am I sure that it is the orbi system's fault? Here is how I eliminated other possible causes:
1. I signed up for two ISP's. One fiber and one cable. The random connection drop issue happens on both.
2. I replaced Orbi with Google WIFI and no drop issue at all.
3. I even re-positioned both RBS50 satellites closer to the router. Literally, the next rooms and the problem still persists.
4. I disabled daisy-chain, MIMU, and fast roaming as per internet suggestions. No dice either.
That pretty much eliminated all other possible causes.
So I opened up a support ticket. The 1st tech had me enabling MIMU and fast roaming and then wait and observe. That did not help at all. 2nd call and 2nd tech from India finally advised me that they have had many calls from users with the same issue. The problem is with the new firmware. Yes, the newest. He advises that they are working on a fix via firmware. In the meantime. Nothing can be done.
My parents have the same 3 unit RBR50 and they have random drops with older firmware. One of my neighbors has RBR40 and he has drops. This is ridiculous. Is anybody else having this issue?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
V2.5.0.38 is your problem.
If you can, try to revert the firmware to an older version.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi satellite losing connection with router
To start with, please try the following procedure and see if this helps:
- Switch off the Satellites
- Go to Attached Devices in the web GUI and click on the "Disconnect" button beside the listed Satellites.
- Turn on the first Satellite, wait few seconds (15 seconds) and then use a paper clip to factory reset the Satellite
- When the Satellite is up after factory reset, press the Sync button on the Satellite (if you have wired backhaul then keep the Ethernet cable to the Router connected while doing the sync) and then press the Sync button on the Router
- When the Satellite is added after this procedure it should behave correctly.
- Repeat the procedure above for the second Satellite.
If the above procedure does not help then we will need to troubleshoot deeper.
Good luck!
My Setup | Internet Fiber ONT 250↓/250↑ | ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750 + 3xRBS350, Wired/Wireless BH / Orbi RBR50 + 6x RBS50 + RBS40V + RBS50Y, Wired/Wireless BH | Switches NG GS208 | Time Zone CET (Sweden)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply. I tried resetting both satellites as you outlined above: waited until power light flash amber and let go. The whole ordeal lasted much longer than I expected: it took a long time for satellites to boot and sync up. Heck, one of satellite was linking with other satellite until I sync'd it with router. Odd considering that I had daisy-chain disabled. But alas, all that effort is wasted. Within 30 mins, I am getting the random drops again.
Something is definitely wrong with either firmware and/or hardware of Orbi. Mine is v1 and the ones I bought for my parents are v2 and brand new. Yet they have the exact same issue as I do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Latest firmware on router and satellites: v2.5.0.38
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the Indian tech was right, it is a firmware issue. But my parents' Orbi had older firmware and it was having the same issue as mine. Sadly, I updated them to the newest. Any suggestion as to which version of firmware to revert back to? And where to download?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Go to the downloads page and enter in your Orbi. Someone here posted the instructions IF an older one is nov available. You might have to do a search
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. I will give it a try.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the ISP modem the NG router is connected too? Any built in router here by chance?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
@WarIsPeace wrote:I have had my Orbi mesh system for close to a year. For the past month or so, I have been experiencing random satellite drop connections. There is no indication from the affected satellite of its aliment. The only way I can tell is by devices connected to the satellite losing wifi, both hardwired and wirelessly. When this happens and I open up Orbi APP or orbilogin.net, then I can see the satellite is having connection issues. If left on its own, it would reestablish connection within 5 mins or so. But this is extremely annoying and random. And it happens multiple times a day that it drove me nuts. How am I sure that it is the orbi system's fault? Here is how I eliminated other possible causes:
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too? Any built in router here by chance?
Give it up.....OP is reverting the firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No modem. Direct ethernet connection from fiber to Orbi router. Besides, if you read my post, I've tried two different ISP's. And I have searched and implemented all the other troubleshooting methods you have mentioned in your post to no avail. It took me far too many hours and headaches to finally arrive at the conclusion that the problem is with Orbi. I need to thank Netgear for releasing buggy as @#$% firmware. One would think they'd field-test their own @#$% before releasing this turd to the public. Who does Netgear think he is? Apple?
Anyways, just flushed both satellites to 2.3.5.30. Let's see how they hold up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@WarIsPeace wrote:No modem. Direct ethernet connection from fiber to Orbi router. Besides, if you read my post, I've tried two different ISP's.
No where in your previous posts did you state NO MODEM. My only recommendations in this thread were to revert your firmware. How did you get the firmware you have now?
I didn't know a Orbi can work without a modem. Perhaps it's not in your house/apartment? Good luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
Correction. You are right, there is a modem. But for fiber, it is enclosed within their junction box. I was thinking inline of cable internet, whereas one need a modem between the RG6 cable and RJ45 outlet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@WarIsPeace wrote:Correction. You are right, there is a modem. But for fiber, it is enclosed within their junction box. I was thinking inline of cable internet, whereas one need a modem between the RG6 cable and RJ45 outlet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Per your instruction, I went to download link, type in my router model, and firmware option came up. Click on release note to download firmware for router and satellite separately.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@WarIsPeace wrote:Per your instruction, I went to download link, type in my router model, and firmware option came up. Click on release note to download firmware for router and satellite separately.
No...I'm asking about V2.5.0.38 - that's the one with the reported problems. see message Message 5 of 18 here.
I thought you said that was the one that started the problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oh that turd. I got it via Orbi's own Online Firmware Update option.
It is still up there as we speak. One would think they would take that virus down. It is not like they don't know about this. Their own Indian tech support knew. It appears lots of us here on the forum now know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@WarIsPeace wrote:Oh that turd. I got it via Orbi's own Online Firmware Update option.
OK...it sounds like you were able to revert back to an eariler version...? That's good. Now leave it alone and stop clicking on firmware updates when you login. NG will push auto updates on firmware that contain major revision. Nice work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Retired_Member wrote:V2.5.0.38 is your problem.
Yeah, using older firmware for a few days. Still getting the random satellite drops/disconnect. When my devices connected to satellite started showing connection issues, I logged into orbilogin.net and can see the satellite disconnected and or other switching to 2.4ghz. v2.3.5.30 was what my parents' Orbi v2 came with. And they had the same issue. So this version of firmware is flawed, it appears.
I should be getting the new Google Nest Wifi today.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oh, get this. I tried to downgrade both satellites and router further to 2.3.1.60. Tried on Satellites first. At first, it worked. Then it auto rebooted a 2nd time and one reverted back to 2.3.5.30 and another to the newest 2.5.0.38. WTF?!!! So I proceeded to downgrade the router. Same issue as the satellites: it reverted back to 2.3.5.30 after 2nd boot.
Yeah, I think I am done with Netgear Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried a factory reset on the RBR and RBS and setup from scratch to see if this helps any? Press the button in back for 15 seconds then walk thru the setup wizard. Something to try as last resort. v60 would have been auto updated to v30. v38 was made available how ever it was given up to the users to update to it or not. Just seen in the UI as something available.
- Mark as New
- Bookmark
- Subscribe
- Permalink
