Orbi WiFi 7 RBE973
Reply
Orbi satellite pinging: 1.0.254.169
jfitty
Does anyone know why my Orbi is trying to ping: 1.0.254.169 and also why it is trying to FTP to Ireland at 52.208.82.166?
Message 1 of 10
Guru
Re: Orbi satellite pinging: 1.0.254.169
What model RBS and RBR do you have?
Do you have anything connected behind the RBS?
Message 2 of 10
jfitty
Orbi Hardware version: RBR50
Running firmware: V2.5.1.16
It is in access point mode
I have an enterprise network firewall acting as my router and is giving the visibility as to what the network traffic from the router is generated.
I am also seeing that there is a good amount of traffic going to AWS for a URL for IoT on port 8883.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 3 of 10
Guru
Whois that IP address belonging too?
Message 4 of 10
jfitty
I keep trying to respond, but my replies are not showing up... the whois shows the IP is registered to Thailand it says it is registered to Dynamic IP Address for residential broadband customers
Message 5 of 10
jfitty
The AWS IoT traffic is going to the US AWS address space on port 8883
The FTP traffic is going to AWS address space in Ireland and is using default FTP credentials.
Message 6 of 10
CrimpOn
Guru
Well, this is unusual.  I have collected every packet that passes through my Orbi router for hours and the satellite appears to ping only the router.  My Orbi is in router mode, but it is hard to imagine the satellite behaving differently no matter what the router mode is.
The firewall definitely shows these ICMP packets coming from the IP address of the Orbi satellite?
Message 7 of 10
jfitty
Yes, it is definitely ICMP and it seems to be 50 packets each time.  They tried to ping the same IP 19 times since 6/10 and today is 7/1.  It is both of my satellites that are pinging this IP.
Message 8 of 10
CrimpOn
Guru
Does the firewall report a "pattern" in what time of day these pings happen?
There are some linux commands that will indicate which process is using ports, but I am not sophisticated enough to know how to capture a historical record over a period of time.
Message 9 of 10
jfitty
No, there is no obious pattern.  Here is from one sattellite:
2020/06/29 10:26:11
2020/06/19 14:38:02
2020/06/18 07:54:49
2020/06/18 07:54:44
2020/06/17 22:15:07
2020/06/17 22:15:02
2020/06/15 09:14:15
2020/06/15 09:14:10
2020/06/14 05:06:14
2020/06/10 18:09:23
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1365 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
