Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi says zero satellites connected... But have Ethernet
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-05-18
06:09 PM
2019-05-18
06:09 PM
Bought a package with the rbr20 router and 2 satellites.
The satellites are connected to Ethernet as well, so it is doubly confusing why it can't see them.
None of the units have lights on, which is usually a good sign.
What is going on?
What is going on?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-05-18
06:31 PM
2019-05-18
06:31 PM
Re: Orbi says zero satellites connected... But have Ethernet
Have you synced the Satellites with the Router?
Syncing is done by pressing the Sync button on the Satellite and on the Router and waiting few minutes until the top ring LED on the Satellite turns blue.
Message 2 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-05-18
06:36 PM
2019-05-18
06:36 PM
Yes, and the lights pulsed white for a while, and then extinguished again.
Message 3 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-05-18
08:02 PM
2019-05-18
08:02 PM
And I can connect to the satellites, and the internet works, but when I try to open the app, it says problems connecting to network.
Message 4 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-05-19
12:29 AM
2019-05-19
12:29 AM
Please login to the Router using a web browser in a computer.
Browse to orbilogin.com and check the status of the Satellites under “Attached Devices”. Let’s start from there and then see what the issue is with the Orbi app.
Message 5 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-05-19
12:11 PM
2019-05-19
12:11 PM
That shows 2 satellites connected via 5 GHz, and good back haul.
Message 6 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-05-19
01:51 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-05-19
03:00 PM
2019-05-19
03:00 PM
The app says zero satellites connected, and when I try to bring up the app while connected to one of the satellites, it faults and says no wifi.
Message 8 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-05-19
03:06 PM
2019-05-19
03:06 PM
- Does the Satellite have an IP address in the same IP range as the Router and the other devices?
- Please check for double NAT situation as follows:
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (traceroute to Google’s DNS server) (traceroute 8.8.8.8 if you're using a Mac computer)
1. If you see two private IP addresses listed in the first two hops then you have double NAT. Please check the model of your ISP modem and if you have a manual for it.
2. If you see only one private address and the second hop shows a public address, then you’re all good with respect to double NAT,
Message 9 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-05-19
04:01 PM
2019-05-19
04:01 PM
No dual NAT.
same first 3 octets.
Message 10 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-05-19
04:08 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-05-19
06:00 PM
2019-05-19
06:00 PM
"- Does the Satellite have an IP address in the same IP range as the Router and the other devices?"
Yes, all of the devices on my network share the same first 3 octets in their IP address.
Message 12 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-05-22
02:50 PM
2019-05-22
02:50 PM
Hi @batpot
May I request for the following information\
- Router and satellite firmware version
- App version? Is it an Android or iOS?
- Have you tried to uninstall and reinstall the app?
Blanca
Community Team
Message 13 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-05-26
02:01 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-07-21
11:45 AM
2019-07-21
11:45 AM
Did a fresh install, which turned into a real PITA, because even after deleting the satellites, and factory resetting them, they would never be found by the app.
Had to also factory reset the router. After resetting router into AP mode, same issue - logging into the router via web interface shows 2 satellites, but app still shows zero.
Firmware is V2.3.5.26 on all devices. App version is Android 2.3.7.622.
Message 15 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-07-22
04:22 PM
Announcements
