- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi with 4 satelites- Some devices are connecting to satelites further away. How do I change that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a orbi system with 4 satelites and I have some devices for what ever reason has connected to orbis that are further away. How can I change that? Is there away to tell the orbi system what satelites devices can use?
I've tried telling my amcrest camera to connect to the satelite that has the strongest signal but it keeps going to the one that has the least.
Is there a way to temp turn an orbi satelite without unplugging it?
THanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi with 4 satelites- Some devices are connecting to satelites further away. How do I change t
Devices choose what signal they want to connect too. Orbi just handles getting them connected to where ever.
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Placement is key. How is the satellites configured and placed? Star formation to the RBR or out in a line from the RBR to the last satellite? Possible you may have too many satellites. Test with only two satellites ON.
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings.
Do you have Daisy Chain enabled or disabled?
THanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
THanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Latest firmware. V2.3.1.48
The orbi connects to a frontier fios unit.
Router mode
approx 3700sqft home
All satelites are connected via a gigabit wire.
I have the router in the garage.
Satelite near family room and then one in my office; Approx 40-50 feet apart.
Second story one on one side of house above the family room and the other above my office about 60 feet away from each other.
Backhaul tried turning off from on.
The other two mimo and beamforming checked
The media one is checked
2.4 set to auto
5 ghz set to 48
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
The orbi connects to a frontier fios unit. Whats the MFr and model of this unit?
Router mode
Are they all connected to the back of the RBR or thru a LAN switch?
The other two mimo and beamforming checked. Daisy chain should be disabled.
2.4 set to auto
5 ghz set to 48
Thanks
