- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi with At&t Fiber 1000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey everyone,
I've been experiencing my internet going out mutliple times a day. My setup is Arris BGW210 Gateway with Orbi AX6000 set as a router. I have ip passthrough with all firewall setting turned off on my gateway. My internet works great for about four or five hours at a time, but will evertually go out. My broadband light will turn red on the gateway as well as the red alarm light on the ONT box that the fiber cable runs into. My question is could my Orbi be causing this? Im leaning more towards something is up with the Fiber cable losing signal.
I also need to mention that my Orbi automatically set its ip address as 10.0.0.1. I have read that is is not a problem.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi with At&t Fiber 1000
If your ONT and ARRIS router are showing RED indications, I would contact the ISP and have them check the lines and there logs for any information.
Orbi should not be cuasing problems.
Yes if Orbi is setting a 10 IP address, this means it's detected the ARRIS is using 192.168.1.1 which is also used by NG, so Orbi changes to something different.
What FW is currently loaded on the Orbi system?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not real sure. I was told i needed to turn firewall off on gateway for the ip passthrough to work properly. Was told that the firewall on the orbi is automaticly on when installed. Does this sound right?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well if it's in IP pass thru, Firewall on the ARRIS modem wouldn't matter as the pass thru isn't effected by the firewall. However, this is correct.
One thing you can do is set the RBR up for AP mode. Remove the IP pass thru configuration from the ARRID modem and enable the firewall on the modem/router and see if anything changes. If the ONT and modem still experience RED indications, then this is still an ISP issue that they needs to look at. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your help. I set the Orbi in AP Mode about a week ago and it still continues to go out. I switched it back to router mode in order to get the benifits that the RBK852 offers. I've called At&t and a tech is coming out Saturday. I've been dealing with this for two weeks now and ready to get it fixed!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya, the ISP needs to have a look. Once they can clear it on there side then Orbi should be good, router or AP mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So whatever happened? Was it an AT&T thing or an Orbi thing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What are you having problems with?
What Orbi model do you have?
@Jramirez730 wrote:So whatever happened? Was it an AT&T thing or an Orbi thing?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
