× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Orbi20
madotom
Orbi20
Lost connection to internet several times. Other items all connected. Trying to determine why the lost connections?
Message 1 of 9
Guru
Re: Orbi20
Both wired and wireless connections are lost?
Message 2 of 9
madotom
Re: Orbi20
Where to I find this. I have no idea
Message 3 of 9
madotom
Re: Orbi20
Arris TM1602A. MTA
Message 4 of 9
Guru
Re: Orbi20
Use a PC or laptop and a web browser, log into the RBR web page at 192.168.1.1 or orbilogin.com
Power OFF the ISP modem and RBR for 1 minute then back ON with modem first. Then the RBR.
Message 5 of 9
madotom
Re: Orbi20
Ok
Message 6 of 9
Guru
Re: Orbi20
Are both wired and wireless connections lost when this happens?
Message 7 of 9
madotom
Re: Orbi20
Just wireless
Message 8 of 9
Guru
Re: Orbi20
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1116 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
