- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi50 won’t connect to iPad mini3
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I feel so stupid. I've been fiddling with this for 2 months and finally asked for help. Your reply put me on the right trail. While going back thru everything I found that my ipad mini had the "blocked" block checked in the Orbi control panel. Why that happened is anybody;'s guess. I certainly don't remember blocking and device. Anyway, you caused me to stumble on the solution. I unchecked the box, and everything is now working fine with my iPad mini3. Thanks for pointing me in the right direction.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi50 won’t connect to iPad mini3
Does the iPad Mini network settings show the password you enter as characters or 'dots'?
It's probably "just me", but I find the iPad keyboard really awkward to use, especially in terms of capitals, lower case letters, and symbols.
Is the Orbi Guest network enabled (perhaps with a really simple password)?
Was the Orbi set up using a web browser, or the 'app'? Sometimes a device can get 'paused' on the Orbi app (by accident).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
