×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
OrbiRBK20
Metcast
Follower
OrbiRBK20
Hi
I Cannot seem to get the Orbi wifi name up on my wifi network. When I'm setting the equipment up for the first time there ie no sight of the link? So I cannot complete installation. All I have is the current network which is Vodafone. Is there a setting in the vodafone router I need to turn off/on? Any help would be appreciated or I will need to return the product.
Message 1 of 4
Guru
Re: OrbiRBK20
@Metcast wrote:
Hi
What do you mean by "there ie no sight of the link"?
Couple things. If you can see a current wireless network from vodafone, it usually means that their modem is a combo device. That can put you in a double nat if you run the orbi in router mode and the vodafone device.
https://kb.netgear.com/30186/What-is-Double-NAT
Explain more on the you can't get orbi to come up on your wifi name. Was this orbi a returned device/refurbished? Someone might have already set it up once and thats why you aren't getting the stock name showing up. you can try resetting it by pushing reset for 7-10 seconds.
have you tried directly connecting a pc/computer to the orbi for setup? It usually goes faster and works better for initial setup? The manual walks you through that.
https://www.netgear.com/support/product/RBK20.aspx
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 4
Guru
Re: OrbiRBK20
Please post about this in the main Orbi forum for your model Orbi:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
@Metcast wrote:
Hi
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 3 of 4
Guru
Re: OrbiRBK20
Any progress on this?
@Metcast wrote:
Hi
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 514 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
