×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
OrbiRBK50
Breakaway9
Guide
OrbiRBK50
I see many people asking about what the icons mean in the app but see no answers. Very simple - I want to assign an icon to my connected devices but your labels don't appear until after they are assigned and saved. Why is this so difficult?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 9
CrimpOn
Guru
Re: OrbiRBK50
Please clarify "what" is so difficult:
  • That the app is hard to use, or
  • That people ask about something "obvious"?
I love my Orbi.
Message 2 of 9
Breakaway9
Guide
Re: OrbiRBK50
Wow. Snarky aren't we? My message is crystal clear. In the app, the device icons lack labels. More simply put, where is the legend? Do you work for Netgear?
Message 3 of 9
ekhalil
Master
Re: OrbiRBK50
Yes the app will only show the icons with no text.
If you want to see the text description then please use the web GUI (orbilogin.com).
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750 + 3xRBS350, Wired/Wireless BH / Orbi RBR50 + 6x RBS50 + RBS40V + RBS50Y, Wired/Wireless BH | Switches NG GS208Time Zone CET (Sweden)
Message 4 of 9
Guru
Re: OrbiRBK50
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 5 of 9
Retired_Member
Not applicable
Re: OrbiRBK50
@Breakaway9 wrote:
.................. Do you work for Netgear?
some in here think they doSmiley Sad
Message 6 of 9
Re: OrbiRBK50
What app are we talking about here? And where are you looking?
My Android Orbi app (V2.4.21.938) shows an array of icons in the Devices slot. And going in through the Network Map also shows icons.
App IconsApp Icons
I can't recall jumping through any special hoops to make that happen.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 7 of 9
ekhalil
Master
Re: OrbiRBK50
I think the problem the OP is reporting is that when you want to select an icon for the device you’ll only see the different icon options but no description or name for the icon.
Please see the attached snapshot.
Message 8 of 9
tomschmidt
Virtuoso
Re: OrbiRBK50
In the app, the icon choices probably do not include their text description due to space limitations on a phone screen, although they could have written the app such that it added the text description on the device screen.  If you use the web interface for the router, then you will see text descriptions rather than the icon when editing, so use it rather than the app for changing the icons for your devices.
RBK53 Orbi AC3000 Tri-band WiFi System (RBR50v1 router and two RBS50v1 satellites) running v2.5.1.16 firmware
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1012 views
  • 4 kudos
  • 7 in conversation
Announcements
Orbi WiFi 6E
