Orbi WiFi 7 RBE973
Reply
Plex, Orbi, sky router and shield
NabsG
I have Plex sitting on a server behind orbi which is connected (wired) to a sky router. Orbi is unstable in AP mode and therefore is in a double nat situation.
I cannot put the sky into a bridge mode. How do I get around this?
Please walk me though and I am not very good with networks.
By the way the sky router sits on 192.168.0.1, and the orbi on 192.168.1.1.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 5
Guru
Re: Plex, Orbi, sky router and shield
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
If you still want to use the Orbi in router mode, then try option #2. For easy use of Orbi with your ISP router, i would use option #3.
Message 2 of 5
weena90
Please walk me though and I am not very good with networks. whatsapp
Same thing happen with me.
Message 3 of 5
Guru
Did you resolve your problem?
Message 4 of 5
Guru
Any progress on this?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 989 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
