- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Port Forwarding kills internet on Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I am having issues setting up port forwarding on my Orbi router, what happens when I set the port forwarding rule up the internet stops working delete the rule and the internet starts working. The rule I am setting up is a port 8080 to an IP address on me network
The set up I have is VM Router in Modem mode Orbi 50 running with one satalite I have checked for double NAT and there is not one I only get the router IP when doing a tracecert
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port Forwarding kills internet on Orbi
Both wired and wireless internet access goes down?
How do you have Port forwarding configured?
Did you disable uPnP before setting up any PF rules?
@Darryl66 wrote:Hi
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is the latest firmware as just down loaded when trying to configuare
set up is just a simple add custom rule port 8080 no special configurations all default likewise default settings on router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry meant to add wireless and hardwire who use hard wire what’s a wire 😀
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please try a different port, say 8181? Same thing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep tried 8080, 8081, 8082 all same restults
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The orbi router is connected to a virgin media super hub 3 this is set to modem mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
And you are getting a public IP address on the Orbi RBR? ##.##.###.###?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not totally sure I’d understand what you are asking
my main router from VM is in full cable mode my orbi then is running in router mode this is also acting as DHCP the public address is there likewise if I do a tracet to 8.8.8.8 I only get my router ip back not my modem as well so no double NAT and like wise the public’s address shows
i am trying to port forward from no-op using port 8080 I have had this working quite some time ago but this was before I saw the light and got an orbi system no Mable to make port forwarding work
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Darryl66 wrote:.......
- Are you sure you've selected Port Forwarding and not Port Triggering when you configured Orbi in the web GUI?
- When configuring Port Forwarding in the web GUI you need to select a service or protocol. Have you made sure that the protocol you're using for your 8080 port forwarding is TCP/UDP? To check this, mark the line and select EDIT SERVICE and check what protocol is being set.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes this all correct it is port forwarding and port 8080
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you please post a snapshot of your configuration when you open "Edit Service" in the web GUI, similar to the attached snapshot.
