- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Port USB du RBS50 - clé USB
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
may I connect an USB drive ou storage on the USB port with Satelite RBS50 ?
Thanks for your help.
Bonjour,
puis-je connecter une clé USB ou un disque externe sur le port USB du satelitte RBS50 ?
Merci de votre aide
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port USB du RBS50 - clé USB
What is the size of the USB drive?
Does it have it's own Power adapter if it's a large size drive.
You can try and see if a USB drive works. Does it work with the Orbi Router?
@Retired_Memberwrote:Hi,
Bonjour,
Merci de votre aide
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I presume it probably will only work on the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did some testing a while back. See this thread https://community.netgear.com/t5/Orbi/Does-Orbi-RBK50-support-USB-Connected-hard-drives/td-p/1332052
