CoreyOLi
Feb 13, 2020Aspirant
Put Orbi in AP mode, can no longer access it
Good evening everyone... Let me start by saying, I've been hammering away at this for a while now, and it's driving me nuts!! I have an Orbi RBK50 with a single satelite, it's a great system... However I have decided to use an Ubiquity EdgeRouter X as my main router and place the Orbi in AP mode... I accessed the web interface just fine (192.168.1.1) first I disabled DHCP (this will be handled by the ER-X going forward) I went into LAN and changed the IP to 192.168.1.2 and then switched it to AP mode... AP mode asked if I wanted static or DHCP I chose station and set IP to 192.168.1.2 subnet 255.255.255.0, etc... Now the really odd part... Now I'm having lots of odd issues, I'll list them below:
1.) Devices connected via the Orbi only get internet access if the Orbi is connect via a LAN port, NOT the Internet Port on the Orbi.
2.) The Orbi does not respond on 192.168.1.2, or any other IP
3.) if I connect the Orbi using a LAN port everything connected to it works, however no connection shows up on the ER-X
4.) If I connect the Internet Port to the ER-X it shows in the DHCP table as 192.168.1.50 (not .2 as I specified) and it doesn't respond to that IP for the gui interface (also unless I ALSO have a LAN Port connected, there is no internet going to devices connected via the Orbi)
5.) Since I cannot access the orbi via the local web interace, I attempted to use the app on my phone connected to the Orbi via wifi... However, I cannot connected locally I have to do it via "Remote Connection" and that will ONLY Work if the Orbi is connected via it's internet port
6.) In the Orbi app under "Router Settings" the Router Information states IP address of 10.0.0.1 (no idea what that is, or where it came from) internet port has IP of 192.168.1.50 with all correct settings via DHCP (even though I set static)
I'm at a loss here.. I can't get into the Orbi in anything but the apps "Remote Connection' mode, so I can't access any advanced features... It's acting as if it failed halfway through converting to AP and is stuck in some sort of a limbo... And since I can't access it, I can't even perform a hard reset and start over...
I'm at a loss here, I've been at it for a bit, and this may sound a bit of an incoherent rant, but I'm really hoping someone has seen this before and can lend a hand?
Thanks,
-Corey
- CoreyOLiAspirant
Well I did a factory reset, logged in, disabled DHCP, set LAN to .210, when I switched to AP mode I left it set to DHCP...
On my EdgeRouter again only working if connected to LAN port on Orbi, is showing 192.168.1.50, however it won't bring up the GUI when accessing that IP, or .210, etc... And again, only works via a LAN port on the Orbi, not the internet port as specified in the instruction for using in AP mode...
Who knows, maybe my device is defective...
I think what most people would do is set the Orbi to AP mode, connect the yellow (WAN) port to the Edge router, and let it get an IP address from the Edge Router using DHCP.
If it is important to have control over what IP address the Orbi gets, that should be set up on the Edge router by using one of its tables to "assign" a specific IP address to the Orbi units (router, satellite). Once the Edge router assigns an IP address to the Orbi, use that address to connect to it.
This is by far and away the best way to deal with this issue, but for the sake of completeness there is another way to get at your Orbi in AP mode.
Even if you don't fix the IP address on the Orbi, you should be able to find it in the usual way, in the list of "attached devices" in your router or with something like the App for your mobile device or the "genie" for your desktop operating system.
Then aim your browser at the IP address.
What I do to avoid confusion and not being able to connect to the RBR in AP mode, set a static IP address ON the RBR when configuring AP mode. I set mine to 192.168.1.50. I set my main host routers IP address pool is 192.168.1.100 to .200. Settings static IPs needs to be outside of the main host routers IP address pool. Once you have this configured, then you can access the RBR in AP mode anytime at 192.168.1.50.
CoreyOLi wrote:Good evening everyone... Let me start by saying, I've been hammering away at this for a while now, and it's driving me nuts!! I have an Orbi RBK50 with a single satelite, it's a great system... However I have decided to use an Ubiquity EdgeRouter X as my main router and place the Orbi in AP mode... I accessed the web interface just fine (192.168.1.1) first I disabled DHCP (this will be handled by the ER-X going forward) I went into LAN and changed the IP to 192.168.1.2 and then switched it to AP mode... AP mode asked if I wanted static or DHCP I chose station and set IP to 192.168.1.2 subnet 255.255.255.0, etc... Now the really odd part... Now I'm having lots of odd issues, I'll list them below:
Thanks,
-Corey
