- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Questions before buying rbk50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I am looking to buy orbi rbk50, and I have both Nest hello doorbell and nest thermostat. I did a bit research online seems that orbi is not compatible with nest products or you will have to trun off the beamforming/mu-mimo to get nest to work. Is it ture?
Thank.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Questions before buying rbk50
You mean Nest products are not compatible with Orbi?
The Orbi just delivers wifi to whatever industry standard you pick, it is down to whatever you want to connect to the wifi to play ball.
You don't say anything about there you did this on-line research, but did it include this?
Search - NETGEAR Communities – Nest hello doorbell
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi RBK50 in AP mode, 100/20 Mbps VDSL2, Arris BGW210 gateway
- Mark as New
- Bookmark
- Subscribe
- Permalink
NEST Thermostats are compatible with Orbi. My two work well with RBK50 and CBK40 systems. I don't have any NEST Cameras.
@Kaiyuanben wrote:Hi,
Thank.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think the issue is with nest doorbell now. Seems thermostat is working fine with orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might do a search on doorbell. There are a few threads regarding this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can temporarily disable the 5Ghz SSID broadcast to see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Check out those other door bell threads. Hopefully you will find something that helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
