Orbi WiFi 7 RBE973
Reply
R8000 as an Orbi Satellite
fordpickup
Follower
Can the R8000 be used as a satellite on an Orbi network (wired or wireless)? I replaced the R8000 with the Orbi system because it constantly would have issues dropping signal. Not sure if I can repurpose it given the current mesh network.
Thanks!
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router, RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: R8000 as an Orbi Satellite
No the R8000 isn't a mesh device.
You can hardwire it in and use it in access point mode. Just make sure to set it with a different ssid and using different channels than orbi uses so it doesn't create interference.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 757 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
