Orbi WiFi 7 RBE973
Reply
RB50 & Ethernet Switch Issue?
finnabbie
I have an Orbi RB50 hardwired to my Xfinity modem via an ethernet switch with one wirelessly connected Orbi satellite. I have had an intermittent issue for years where wifi network wlll stop working and the Orbi base will have the magenta LED ring. The issue always appears overnight. This issue can be resolved by unplugging and replugging the ethernet switch (Netgear GS108). Sometimes it goes months without occuring, but sometimes it happens several times in a week. Before I power cycle the switch it will have the green port lights blinking in unision, rather than some solid and some flickering randomly per usual.
While annoying, power cycling the ethernet is easy enough to do. However, when I am away it is beyond what members of the household can do. I'd like to get the system functioning more consistently once and for all.
  • Does anyone else have any experience or issues with this ethernet switch?
  • Is there a reccomended switch that plays nice with the Orbi?
  • Is there another issue I am missing (Orbi setting, something on my network, modem side issue)?
Thanks in advance!
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 6
Guru
Re: RB50 & Ethernet Switch Issue?
Is the Orbi system operating in Router or AP mode?
Directly connect the Orbi base to the ISP modem to test with out the switch in the middle to see if anything changes. Possible bad switch, however I doubt it.
CAT is recomended LAN cable type between the modem orbi RBR and all other wired devices.
Message 2 of 6
finnabbie
Current router firmware version is 2.3.5.30. I'm not sure if this automatically updates, but I can check for updates if that is advised?
The modern is a Cisco DPC3941T (Xfinity XB3)
Orbe system is operating in Router mode
I have previously tested the setup without the switch and it seems to work fine. Again though, the problem only occurs intermittently and sometimes infrequently.
Message 3 of 6
Guru
Well your ISP modem is a modem and router.
https://www.cnet.com/products/cisco-model-dpc3941t-docsis-3-0-24x4-wireless-residential-voice-gatewa...
Is the modem bridged or in router mode? Bridge is recommended...
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 4 of 6
finnabbie
Thanks.
The Xfinity router is currently in Router mode. When I first set the system up, I tried it in Bridge mode and my setup didn't work at all. I forget what the specific issues were but I can test it again. I will also try some of the other approaches and report back on how it goes.
Message 5 of 6
Guru
Try bridge mode on the modem again. Be sure to apply the setting and let the modem reboot. You may want to power OFF both modem and RBR for 30 seconds, then back on with the modem then the RBR. The RBR should connect.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 848 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
