×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RB50 router v satalite
Devinefamily4
I have RB50 router & 2x satellites. The system works fine but I need to add another ‘satellite’ in a garden room. I purchased a new box thinking it was a satellite but bought a router instead.
Can I use the router as a satellite and connect to my existing satellite?
How would I do this? Tried adding satellite using app but will not let me do it.
Any advice please?
Message 1 of 4
Guru
Re: RB50 router v satalite
RBRs can only work as main routers or in wired AP mode. Can't be used as a satellite.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
CrimpOn
Guru
Netgear's decision to not allow RBR products (routers) to function as RBS products (satellites) has frustrated customers since the beginning.  The actual hardware for the "50" product is identical.  Other manufacturers chose to make their products interchangeable, but Netgear did  not.  In the case of this specific model (RBR50), some very clever person found a "hack" which transforms the router into a satellite.  Internet search will turn up links to the process. I, myself, have never tried it.  Netgear doesn't offer any support.  It would certainly void the warranty, but there's no warranty on used equipment anyway.
So, @FURRYe38 is correct.  Unless you want to go "down the rabbit hole", you're stuck.  You can run an Ethernet cable to the garden room and deploy this unit in Access Point mode.  It will remain a separate WiFi network, so devices will not "roam" seamlessly between the main system and that unit.
Bummer.
I love my Orbi.
Message 3 of 4
Devinefamily4
Thank you for the explanation & info.
Message 4 of 4
Discussion stats
  • 3 replies
  • 338 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
