× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RBK13 Firmware update problems
dl42
Anyone else seeing any issues with Firmware Version 2.6.2.104 on RBS10 and RBR10?
My RBK13 (AP mode) setup would stop working - no wifi connectivity - about once a day after upgrading to this version.   Switch it off and on again and all good till the next time.
Reverted back to 2.6.1.44 and all looks solid again.
Message 1 of 6
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: RBK13 Firmware update problems
Hi @dl42
As suggested by @FURRYe38, have you tried factory resetting the device?
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
Message 3 of 6
All Replies
Guru
Try a factory reset and setup from scratch next time FW is updated...
Message 2 of 6
Blanca_O
NETGEAR Moderator
Hi @dl42
Blanca
Community Team
Message 3 of 6
dl42
Not as yet.
Wanted to just validate that the issue was the fw and not something else(hw?) as it dod seem to be random.
Looks to be the case as everything has been solid again since I reverted to the old fw version.
Will try and find time to do the factory reset - though why it should be needed is another matter.
I take it I'm the only one seeing this issue?  Is it because I am running in AP mode?
Message 4 of 6
dl42
The factory default and then update seems to have resulted in a solid network once more.
Message 5 of 6
Guru
Enjoy.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1172 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
