× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RBK20 WiFi cant connect to Wired devices
JordonMusser
I am trying to ping a wired connection with a device on the WiFi and it doesn't work.
I am using the ORBI in AP mode, with a FIOS router for DHCP.
Everything else works fine, I just can't connect directly to a computer that is on the wired network from one on the wireless. In this case I need my phone to connect to my smart home controller.
Message 1 of 9
Guru
Re: RBK20 WiFi cant connect to Wired devices
Is these devices connected to the RBR, RBS or do you have the wifi running on the ISP router and devices connected there?
Message 2 of 9
JordonMusser
Wired:  I wired it to both the switch (connected to router) and also directly to the RBR with no change.
Wireless:  I am believe Ive been connected to the RBR and BRS with same issue.
Message 3 of 9
CrimpOn
Guru
I regularly ping devices on my Orbi network and have been surprised to learn that some of them do not respond to ICMP (ping) requests.
My Nest Mini, for example, happily responds to ping, but my Echo Dot does not.  In a similar fashion, I was frustrated that a Windows computer would not respond to ping until some nice forum member pointed out that the Windows Firewall default is not to respond. Once I told the Firewall ping was OK, my testing got a lot easier.
Does this home controller respond to ping when a computer that is wired to the same FIOS taht the home controller is wired to?
Message 4 of 9
JordonMusser
actually. no, I didn't even think to try that.  That doesn't work as well.  So it appears it may be a router problem and not orbi?
I can access the home controller using their service, so I know its accessible (if I run my phone on 4G LTE i can reach it via the service)
Message 5 of 9
CrimpOn
Guru
Most Internet of Things (IoT) devices create a link to the "Cloud" (this is not a security breach because the link comes from inside the LAN to the cloud, not from the outside)
I would expect that the smartphone app would work when the phone is connected to Orbi WiFi. (Mine certainly do, and I have about a dozen).
On the question of ICMP (ping), that would be something the home controller company could answer. "Does it, or doesn't it?"
Message 6 of 9
JordonMusser
The device is a solid state windows PC, and has worked for 7 years+. This problem only came up after I upgraded my network to ORBI for wifi, and a new main (fios) router.
Looks like it may be in the router, not sure!
I can connect to the PC from a computer on a VPN, or connected to 4GLTE.  Just not on the local network.
Message 7 of 9
CrimpOn
Guru
This may be a consequence of having two routers (FIOS and Orbi), which is often described as a Double NAT situation.
https://kb.netgear.com/30186/What-is-Double-NAT
If the PC is connected directly to FIOS, it will get an IP address from the FIOS router.
Devices connected to the Orbi will get an IP address in a different subnet from the Orbi router.
WiFi devices will "know" that the FIOS subnet is "out the internet port of the Orbi" (somewhere) rather than on the Orbi subnet.  So packets go to the FIOS which directs them to the PC.  When the PC responds, however, FIOS has no idea where to find the private IP space that the Orbi created.
This can be verified by finding the IP addresses of the PC, the Orbi, and the WiFi device.
If this is the case, common solutions include:
  • Connecting the PC to the Orbi rather than to the FIOS
  • Putting the Orbi into Access Point (AP) mode
Message 8 of 9
Guru
If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1398 views
  • 4 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
