- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK23 connecting to NBN Arris not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I am trying to connect a new Orbi Netgear router to the NBN arris box.
My service provider is internode and it looks like they only want to support a few router brands of their choice.
Is it possible to configure the Orbi to make it connect.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://www.netgear.com/support/product/DM200.aspx
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBE971 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK23 connecting to NBN Arris not working
Internode use VLAN tagging for their HFC NBN connections.
You need to enable that and set it to VLAN2 for it to work.
https://www.internode.on.net/support/guides/general_settings/
HFC/FTTC: Ethernet WAN (with 802.1q VLAN 2)
https://forums.whirlpool.net.au/archive/2758953
(shouldn't need to do the mac cloning though)
In the Orbi config -> Advanced Settings -> VLAN section and set the "Set VLAN by group" option for internet to VLAN ID 2.
*note - you may need to update your firmware first.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@TimD5000 wrote:Hi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry for late response
Model # is Arris CM
Firm Ware is V2.3.5.30
- Mark as New
- Bookmark
- Subscribe
- Permalink
@TimD5000 wrote:
Model # is Arris CM
Not a lot of help. CM probably means cable modem. But Google shows a whole raft of CM model numbers.
The full details could be important. Especially of your "CM" is also a router.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P- Mark as New
- Bookmark
- Subscribe
- Permalink
CMs are only modems only. No built in router. C series modems are the modems with built in routers.
Thought it would be nice to know the CM#### model # here.
HE should be good a far as NAT and connection with the RBR and CM modem if there isn't anything else in between them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's Netgear. Google is less than clear on other brands.
Then there are variants with limited routering. Think DM200.
So I don't make assumptions.
- Bookmark
- Subscribe
- Permalink
I always presume that NG information is most accurate.
DMs are always DSL Modems. Modems only. D series is modem/router units.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have no idea what point you are trying to make.
The DM200 is a DSL modem with built-in router features that you have to disable if you want to use it with a router. That has confused several users in the past.
Been there. Done that.
Why not just go off an harass some more Netgear people? I am sure they appreciate it.
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not trying to harrass. I think you take my posts out of context.
Anyways. Hope this is solved.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thankyou for your help
Yes managed to sort out with a firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear. Thanks for letting us know.
I would make a back up configuration of the router to file for safe keeping.
Enjoy.
