- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK23 won’t connect to internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently purchased a RBK23 Orbi mesh. My ISP is Optus. Problem is that it won’t connect to internet, either via WIFI or using username and password. I’ve tried a million times, but to no avail. There is nothing wrong with my internet and I’ve called Optus to say there are no dropouts...so help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK23 won’t connect to internet.
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too? Any built in router here by chance? If so,
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ricodafool wrote:
Thanks, but I’m not sure if that’s the problem. I have NBN and then a Sagemcom modem. No other router. There’s no problem with internet in the room where the modem is, but for some reason the Orbi just wont connect to the Internet. I’ve tried the Advanced settings, but it didn’t recognise the PPPOE login details that I entered. Getting pretty frustrated, as spent a lot of money, but just can’t get it to work. I’ve tried calling Optus (and after waiting 90mins) they said no dropouts and Internet is fine, but they’ll call me back.
Does your sagemcom modem have a router built in?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure your PPPoE settings and input values are correct.
Does your ISP required PPPoE on the router or just the modem? If only the modem then you don't need PPPoE on the RBR. Use DHCP.
I would contact your ISP and have them help you ensure your modem is setup correctly and find out where PPPoE needs to be at.
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://devicehelp.optus.com.au/sagemcom/gateway-f-st-3864-mac-os-sierra/
I’ve also got an NBN connection box, with Ethernet cable to the modem/router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I used the ppoe login details on bottom of modem, but it didn’t recognise them.
I’ll try and call my ISP again to confirm all the details.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try option #3 if you can't seem to get PPPoE working...
@ricodafool wrote:
Yes, I it’s a combined modem/router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
“Be sure to power OFF the ISP modem and RBR for 1 minute then back on with the modem. Power ON the RBR. Factory reset the RBR by pressing the back reset button for 15 seconds then release. Connect 1 wired PC to the back up the RBR and walk thru the setup wizard in a web browser at 192.168.1.1.”
- Mark as New
- Bookmark
- Subscribe
- Permalink
You don't need to reset the RBR you can go directly into the RBR and configure AP mode.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
IF your modem already has a built in router, then configurting the Orbi for AP mode should work for this configuration.
What mode is the modem working in. Briidge mode would be preferred then you could use the Orbi in router mode.
Some suggestions for modem route combo units:
https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-an...
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
