Orbi WiFi 7 RBE973
Reply
RBK40 (RBR40 & RBS40) - disable wifi broadcast on satellite?
Bob-Loblaw
Follower
Hi all-
I have an RBK40, which is the RBR40 router, and RBS40 satellite.
We just moved and I no longer have a need for the increased range the satellite offers. But I am using the satellite because I have my desktop PC connected to it via Ethernet.
My question is, how can I prevent the satellite from broadcasting wifi, while still allowing the Ethernet port on it to work? Basically i want my hardwired desktop to be the only device that is connected to the satellite
I have found that in my current setup, sometimes devices are connecting to the satellite instead of the router, which is reducing speeds. The router and satellite are only ~12 ft apart.
thanks in advance
Model: RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 3
CrimpOn
Guru
Re: RBK40 (RBR40 & RBS40) - disable wifi broadcast on satellite?
Netgear does not provide a method to "turn off a radio".  The entire point of  the product is WiFi.  There may be a "hack" using telnet to disable satellite radios.  I have no personal knowledge of how to do it, or whether the hack survives a restart, after a power outage for example.
12 ft. is considered "too close" for a satellite.  You might want to reduce the transmit power level on the Orbi system.
Message 2 of 3
Guru
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
@Bob-Loblaw wrote:
Hi all-
thanks in advance
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 528 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
