Orbi WiFi 7 RBE973
Reply
RBK44 | Latest firemware issue | 2.3.0.28
fatnasa
Tutor
Hello,
every thing was working just fine with v2.2.1.210 however one i have updated to 2.3.0.28 everything went mad as below :
-  all Satellites are going up and down "no more stable connection"
- Backhaul Status is updated ever 5 to 10 secounds (config sync ==== >  status ==== > config sync ==== >  status ...etc)
- android app doesn't show my Satellites connected (sometimes 1 or 2 or 3 but it's not stable with every refresh) which wasn't the case beofre FW upgrade
once i have downgraded again to v2.2.1.21 , everything is working back  again as expected.
note : i have been testing this for 2 weeks
hope you can check what's the issue with the Latest firmware
Model: RBK44| Orbi AC2200 WiFi System
Message 1 of 6
Guru
Re: RBK44 | Latest firemware issue | 2.3.0.28
Please do a full factory ERASE on the satellites and RBR and setup from scratch.
Ensure the Android app is up to date as well.
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Post your experiences here please:
https://community.netgear.com/t5/Orbi/New-NetGear-Orbi-20-40-Series-Firmware-Version-2-3-0-28/td-p/1...
@fatnasa wrote:
Hello,
Message 2 of 6
fatnasa
Tutor
i have already performed full factory reste but that doesn't help, also note that Android app is up to date.
the RBR40 is connected to Peplink balance one while the orbi system is operating in  AP mode
my house is around 4000 square feet
the distance between the router and satellite around haven't been changed since a year , while V2.2.1.210 is installed everything seems to be stable but while 2.3.0.28 is deployed everything went mad Smiley LOL
Message 3 of 6
DickDuke
Apprentice
Did you update the satellites BEFORE updating the router firmware? The satellites can have all kinds of trouble if the router is updated first. Also, if you are doing a manual firmware update, be sure to download and load the correct firmware for each device.
Message 4 of 6
fatnasa
Tutor
yes , the satellites  have been updated successfully before the router.
and i have used the correct firmware file for each device
satellites === > RBS20 FW file
Router === > RBR40 FW file
Message 5 of 6
fatnasa
Tutor
i have tested the new FW ==> 2.3.1.44 and i am still facing the same issue.
so i have downgraded again to 2.2.1.210
does any one know how can i fix this?
thanks in advance.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1585 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
