Orbi WiFi 7 RBE973
Reply
RBK50V Orbi Voice Can not go back to Satellite mode
clvk07
Tutor
Hi
I put the Orbi voice in extender mode, (had to flash the extender firmware) and now when I try to flash the orbi mode firmware it fails (upgrade failed check the file), any suggestion on how to revert back to satellite mode?
Message 1 of 7
Accepted Solutions
Guru
Re: RBK50V Orbi Voice Can not go back to Satellite mode
Flashing the firmware doesn't switch mode. There's 2 versions of firmware on the RBS40V and the satellite actually stores them both. It switches between them based off switching mode.
https://kb.netgear.com/000061089/How-do-I-set-up-my-Orbi-Voice-in-Orbi-Mode
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 5 of 7
All Replies
CrimpOn
Guru
This is the original RBS40V, correct? (not the RBS40v-200?)
I love my Orbi.
Message 2 of 7
CrimpOn
Guru
@clvk07 wrote:
Hi
Did you attempt firmware load through the Orbi router Advanced Tab->Administration->Firmware Update-> Manual Tab, or by connecting directly to the RBS40V web page?
I love my Orbi.
Message 3 of 7
clvk07
Tutor
@CrimpOn wrote:
@clvk07 wrote:
Hi
Hi
Yes it is the original RBK40V.  I reseated the voice to factory settings, connected to the netgear_ext SSID IP 192.168.1.250 and then went to advanced, firmware manual upload
Message 4 of 7
Guru
Message 5 of 7
clvk07
Tutor
tried that all good, thanks
Message 6 of 7
Guru
Glad it fixed it for you!
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 979 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
