Orbi WiFi 7 RBE973
Reply
RBK53 and Tapo Camera
Matteo87
Follower
Good Morning,
I'm trying to connect a Tp-link Tapo Camera C200 to my new Netgear RBK53 Mesh wifi network, but there is no way to complete the link. It seems that the camera is not able to read the network.
Before it was directly connected to the wifi network provided by the ISP router and worked correctly.
Do you have any idea/advice ?
Thanks in advance
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
Guru
Re: RBK53 and Tapo Camera
That camera is a 2.4ghz camera. Some setups have issues when the phone is on 5ghz and the camera is only 2.4ghz.
Tends to be a sign of poor coding on the app setup.
Try using a device on 2.4ghz for setup.
Message 2 of 3
CrimpOn
Guru
@Matteo87 wrote:
Good Morning,
Has the camera been "reset"?  At which point in the setup does something go wrong?
https://www.amazon.com/TP-Link-Tapo-Wireless-Security-C200/dp/B0829KDY9X/ref=sr_1_1?crid=3J584THTX1D...
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 887 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
